I recently bought a used Sigma 24mm f2.8 Mini-Wide II. I have 2 problems, not sure if they are related or not.
The first is flare. I see in the reviews that some reviewers say this lens is prone to flare. I find the flare objectionable and it also seems to create a haze or fringing around bright areas. In a nice evenly lit scene it is fine and seems to be a sharp lens otherwise.
A couple example photos are attached.
The second is that I have to underexpose by about 1 1/2 stops to get a good exposure, particularly in outdoor shots like the scene attached with red bush. A good, evenly lit situation it is not as far off, but still requires underexposure. I am using a K20D. I do find that I often lean to underexposure with my other lenses also but maybe 1/2 stop typical.
So I am just seeing if anyone has thoughts. The flare problem could be just a characteristic of this lens? Is there a way to calibrate the exposure if it is off?
Thanks in advance.
