Originally posted by Cory Tarilton My superprogram will not meter in a selected aperture for that lens, nor will it allow manual aperture input via the camera. It defaults to F22 and does not allow any other selection. When in A-mode, it also only meters at F22. It will, however, meter and allow selection for my other two lenses
I don't know what metering has to do with any of this. From your description, it appears that the aperture mechanism in your 70-200 lens is not functioning correctly (remains at f/22).
Your Super Program should support any lens K-mount lens that has an aperture ring and/or "A" contacts on the mount.
If a lens lacks an aperture ring, functionality is limited to program and shutter priority modes only. Film cameras having a dial for aperture control on the camera support will support both Av and M modes with lenses lacking an aperture ring.
Since two other lenses (both lacking aperture rings) work to your expectations on the Super Program, it is safe to assume that the 70-200 has a problem. Are you able to manually work the aperture actuator with the lens off the camera? Is the lens wide open when mounted to the camera? (It should be.) Is there any indication of damage to the aperture actuator lever?
(...owns Super Program Camera...has used it with lenses lacking aperture rings in both program and shutter priority modes...)
