Ok, things are a bit more nuanced than I originally thought.
With more careful testing I have identified a more accurate description of what is going on:
@ f/4.5 a 52mm step-down ring produces almost indiscirnable vignetting on a Pentax crop-sensor body with the exposure being about 1/3 stop darker in the center and 1/2 stop darker in the corners. So there seems to be something to the concept of diffraction coming into play here.
The following list identifies what step-down rings are usable at specific apertures with no measurable difference in exposure.
- @ f/4.5 a 58mm step-down ring produces an identical exposure as no step-down ring
- @ f/5.6 a 55mm step-down ring produces an identical exposure as no step-down ring
- @ f/7.1 a 52mm step-down ring produces an identical exposure as no step-down ring
- @ f/9.0 a 49mm step-down ring produces an identical exposure as no step-down ring
As such, I was wrong in my initial impression -- sorry for any confusion I may have caused. However, I can say that should you need to use a smaller filter than 67mm on your FA* 300mm f/4.5 you can with confidence using the above as a guide.
Michael
P.S. I might add that at no time did I ever see any classic "black" vignetting regardless of the size of the step down ring or aperture. So this lens definitely behaves differently than my DA* 60-250mm and there is some magic going on here.
