Originally posted by audiobomber
Have you tried the Tamron TC with your DA*16-50mm Lenny? I bet there's quite a significant difference. Non-screw-drive lenses I've tried (DA 18-135mm, DA*50-135mm, DA*300) do not auto-focus reliably with my Kenko.
I can't say
how much better or faster the AF is on the Pentax HD 1.4 (because I don't have one), but I have the Kenko 1.5 Pz-AF, and it
does focus with the Pentax DA* 60-250mm which is a non-screw drive SDM lens
---------- Post added 11-11-2015 at 03:56 PM ----------
Originally posted by jpzk
Sorry to barge in.
That is an interesting idea.
I wonder if the Pentax HD 1.4X TC would work well on my lens (DA*16-50) which has been modified to "screw drive" only?
Gotta try that!
I'm curious why one would want to use a teleconverter on a wide-to-normal lens, when native focal lengths are available without the extra weight and glass? I'm not arguing and don't know the answer, that's why I'm asking.
It seems you could just use a DA 70mm, FA 77mm, or 100mm lens and have the length you need. I guess my point is that I see using one when there's little to no longer glass available, especially for under thousands of dollars, so it makes sense on a 300 or a 60-250. But on a 16-50, for the same price as the TC, you can buy a DA 70 Ltd and probably be much better off. Probably, I'm missing something....
