Hi,
I am by no means good at photography
But I primarily shoot my daughters' gymnastics and other sports - as a non pro, father on the sidelines.
I agree with you narrowing down to the 70-200 and the 60-250. Those were 2 of my final choices for sports.
Realize that with the 4 different events, you may not be able to get very close to all of them - the zoom is definitely better than the primes.
I went with the 70-200 Tamron on my K-3. I feel like I got pretty good shots of my daughter even thought I was not an experienced shooter last year.
I am a little better this year and her first meet is Saturday, I am hoping to get better shot with my "improved" technique.
I do NOT think I would be able to get as good of pictures with the F4 - lighting has been very patchy and not bright at the venues.
I miss the extra reach I could have gotten with the 250 or a 500 - I want more reach for the outdoor sports... but those lenses are not fast enough for indoor gymnastics.
Regards,
---------- Post added 12-09-15 at 05:31 PM ----------
Originally posted by klh Gymnastics is one of the hardest subjects (other than swimming) that I have done. Fast movement and low light. As others have said, you will want f/2.8 lenses or better. I typically brought both my Tamron f/2.8s (28-75 and 70-200) and switched back and forth depending on where the action was. I did find the K-3 was a huge step up in focus speed and accuracy over the K-5.
My first tip would be to prefocus (I manually focused) on beam, bars, and vault. The K-3 is great for that with the focus-peaking feature. It's not easy for the camera to pick out the correct focus points if you're sitting in the stands because of all the background activity (other equipment, gymnasts, etc.). I also tried to stop down at least a half to a full stop to get a little sharper shots, and bump up the ISO until shutter speed was at least 1/500 or better. For floor, I tried to know my daughter's routine and again prefocused for the first shot when the previous gymnast was performing, and I even stopped down a little more in hopes of a better depth of field. After that, I did my best, but the keeper rate for floor routines was pretty low.
Hi,
Please tell me what is so hard with shooting water events?
My daughters are doing synchronized swimming this year for the first time.
I have been shooting for only a while now with my K-3 and 70-200, mostly gymnastics and outdoor sports.
For water sports, is it the indoor lighting that is tricky?
Reflections from the water?
Is there a resource that you know of that I can review in regards to shooting water sports?
Thanks!!!
