Originally posted by troika That sort of helps a bit, thanks. It still doesn't quite reconcile for me why some people report "great from wide open" and others say "unusable wide open". Unless either their expectations are different going in or there's copy variation.
Generally with tests, especially of vintage lenses, I don't assume that they tested 5 copies and gave the average.
It is a good data point, though. I'll give it some thought. I really appreciate all the input I'm receiving.
To me photozone and my experience match. Klaus recognize the lens contrasty and I recognize the lens make the subjects pop. To me really the FA*24 is not a bad lens, it is great because of that property. But this is not say a lens that does everything well, in particular not at all appertures.
We could have got 2 bad copies, sure. But I think this is not that. My lens is sharp closed down and give then great results.
To me different people have also different level of expectations. I don't know were are your expectations. Me I have only primes right now and 2 in my bag are extremely sharp: DA35 ltd, FA77. The DA21 is sharp but the field curvature can be anoying. That's the same with the DA15. In your case your low light shoot really doesn't show much details so you should be able to take something as good I think.
If really low light performance was key to me and I'd wanted a set of light primes not needing much a tele, then I'd consider A fuji with say 23mm f/1.4...
