Originally posted by DanGleabols
My finger is hovering over the buy button for a good priced 70mm HD, I really want a portrait lens. I will admit I have the usual Da70 mm vs Fa 77 decision going on in my head. Realistically, I think even a used 77mm is stretching my budget a bit far. I also suspect buying the 70mm, a couple of extra strobes and some reflectors, and still saving money would be better for my photography than just the 77. But I'm just constantly blown away by the portraits I see taken with the 77.... but that might be more down to the quality of the photographers using it!
The FA77 and DA70 are indeed quite different. The FA77 has better bokeh, warmer colors and make the subject pop more on top on having a wider apperture (1 stop wider). The biggest issue is the purple fringing at large apperture in difficult conditions and lack of quick shift.
The other has more flare resistance is optimized for digital and offer a more "clinical" rendering that is to me much more common theses days. The biggest issue is that the max apperture make it not so different "spec wise" from an f/2.8 zoom like 50-135, 70-200 or 24-70.
To me you can make the FA77 do everything the DA70 does, but the contrary is not true. Mostly for the larger apperture and a bit for the pop/pixie dust. If you take the DA70 while the lens is great you'll wonder whatif I had taken the 77. While if you have the FA77 you'll never look back.
The key reason for going the DA70 route to me is to keep a budget and that's perfectly valid one.
