06-26-2008, 12:00 PM   #1
Various old lenses, will they work?
Hello,
I have just purchased a Pentax 200D and would like to know if any of the lenses I have from my Program A's and ME Super will work with this lovely camera.
Also what would I need to do to get them to work?
The first is
A Sears Multi coated 80- 200mm Auto Zoom 1:4.0 it has an A in brackets
A Takumar ( Bayonet) 135mm 1:2.5 - quite fond of this lens.
2 x SMC Pentax A 50mm 1:1.7
any help would be very much appreciated
06-26-2008, 12:05 PM   #2
This link should get you started
K100D (Super) Pictorial guide to using manual lenses [imgs] [Page 1]: Pentax SLR Talk Forum: Digital Photography Review
06-26-2008, 12:11 PM   #3
gokenin's Avatar
yes
once you have the camera switched on to allow aperture being set by the lens you can use any manual lens on the camera.
06-26-2008, 12:13 PM   #4
Tom S.'s Avatar
MrApollinax's link is excellent. The short answer to your question is any old Pentax bayonet lens will work on the camera, period. Some may require manual settings. Even the old screw mount lenses will work with an adapter.
One the beautiful things about Pentax!
06-26-2008, 12:16 PM   #5
Thank you so much this is a great start..
06-26-2008, 05:34 PM   #6
Stratman's Avatar
Woo hoo !! Another Missourian ( no idea where Weston is though ) , welcome to the forums Chris. You can definitely use all of those on there, and especially the A 50 F1.7, that is a really popular lens , sharp, and really nice.
06-26-2008, 05:53 PM   #7
I did something wrong
Well I tried the method to find the meter reading and it didnt change the speed, infact I even tried the method with an A lens and a straight manual lens both didnt read the light - have I missed something?
06-26-2008, 06:01 PM   #8
I think I found the error, on the 200D there is a green button next to the shutter, if you press this it steps down the lens to the correct shutter speed in manual mode, and then it appears to work , rather than use the Ae-L button which doesnt work.
06-26-2008, 06:08 PM   #9
Blue's Avatar
QuoteOriginally posted by ChrisC Quote
Hello,
The first is
I have a sears 80-200mm Auto Zoom that has a KR mount (sear term). I bought it new 20 years ago and used it on my K1000, Chinon CP-7m and P3 without in problems. It won't work with my K200D. I suspect it has something to do with the Ricoh. I have 2 other sears lens that about about the same time, both 135mm. One works fine on my K200D, the other one doesn't. Sears lens had a mount that they referred to as KR in reference that they were supposed to work in program mode for Pentax KA and Ricoh RK. I actually like the 135s but have never got the best results out of the 80-200mm.
Other lens that I tried and work o.k. with it include my Tokina 400mm 5.6, SMC A 400mm F5.6, SMC A 50mm, several Tamron Adaptall with pk adapter (pka adapter will be more compatible). I have also used my m42 lenses o.k, macro-takumar 50mm (true 1:1) and two 55mm F1.8 (Super tak and SMC tak) with no problems.
06-26-2008, 06:14 PM   #10
I didn't realize that the 200D has a green button. This is a holdover from the K10D. The green button on your camera will function as the AE-L button would on my K100DS
06-26-2008, 06:27 PM   #11
Hi,
Thanks , once I figured it works great , well apart from the Sears lens..with a KR mount
I just found another one - its a 55mm-135mm JCPenny 1:2.8f multi coated K Mount not sure if this will work either?
06-26-2008, 07:14 PM   #12
If you like manual focus, grab one of those Pentax A series 50mm 1.7 lenses. You will NOT be let down. Fantastic fast 50.
I also have an A series 50mm 2.0 for $40 if you are unsure of the condition of those 1.7s. The 2.0 is also a great lens. The A setting allows use of all automatic program, picture, and scene modes, and use of the flash (auto sync). Both the 1.7 & 2.0 will net you some beautiful crystal clear pictures worthy of the K200.
k-mount, lenses, pentax, pentax lens, slr lens
Which prime lenses would work well? Vantage-Point Photographic Technique 9 11-08-2010 12:38 PM
Lenses that work with K-7's corrections Q LeDave Pentax DSLR Discussion 9 12-04-2009 08:11 PM
Will these lenses work with DSLR? trk105 Troubleshooting and Beginner Help 10 06-14-2009 07:05 PM
Will these lenses work with... rmtagg Pentax SLR Lens Discussion 7 03-14-2008 01:05 PM
Does pentax still work on A lenses? barondla Pentax SLR Lens Discussion 1 11-20-2007 04:56 PM
All times are GMT -7. The time now is 09:25 PM. | See also: NikonForums.com, part of our network of photo forums!
