UPDATE:
so i spent some time making the AF adjustments according to the tutorial on the mainpage:
"The adjustment process is quite simple:
Choose a clear subject that has something in front of and behind it (lens alignment tools work best)
Take a photo with autofocus enabled
Check if focus is accurate on your computer monitor at 100% magnification
If things in front of your subject are sharper than the subject itself, apply a -1 focus correction and start over from step #2
If things behind your subject are sharper than the subject itself, apply a +1 focus correction and start over from step #2
If your subject is perfectly in focus, you are done!
Read more at: https://www.pentaxforums.com/reviews/lens-align-front-back-focus/the-remedy.html#ixzz3smunlkYL"
and i had to apply a full +10 to get it to an okay level:
now the extreme FLs 16mm and 50mm are a tad (maybe -1) too front focusing, while the medium range (20,28,35mm) are still back focusing by about +2. However i cant test this as I am at the maximum with +10.
That seems a little odd maybe. however i used a common ruler. The focus distance was about 0.6 meters or just a hair below 2 feet, according to the scale on the lens. I havent done any infinity testing yet.
See for yourself below (Focus Point is between the 70mm and 71mm mark):
50mm f2.8 AF +10
28mm f2.8 AF +10
