Originally posted by seb.leclerc The DA 35mm f/2.8 Ltd. Macro is a razor sharp jewel of a lens and is a practical focal length for street photography as it approximates what your eyes see. Also as a macro, you can get extreme close ups, albeit at a certain point it is less practical as a macro (vs. a 100mm macro) because you are physically so close that you cast your own shadow into the shot or scare of little critters. Also the DA 35mm has auto focus with quick shift, whereas the M 50mm f/1.7 is more of a short telephoto (manual focus) that is really nice for portraiture and shallow depth-of-field.
Another consideration for a second lens is to look at your metadata. What percentage of your shots are done at 18mm? 135mm? And in-between? If a majority are at the wide end, perhaps you should consider a wide angle prime under 18mm? Or a majority at 135mm, then perhaps you want more reach like a 55-300mm? If that isn't your thinking, and unless you want portraiture, the DA 35mm f/2.8 Ltd. Macro will give your K3 amazingly sharp images with great color rendition.
