12-01-2015, 08:31 PM   #1
Newbie question: does the metal ring on 60-250mm lens come off?
sorry for the question. I just got the lens -- kinda hefty. In any case, I have managed to take off the L shaped tripod support thingy. Does the cast iron metal ring come off as well off the lens or I am stuck carrying it even when not using a tripod ?
Thanks a lot.
12-01-2015, 09:07 PM   #2
QuoteOriginally posted by redridinghood Quote
Thanks a lot.
I'm pretty sure it stays on, but you should be able to rotate it so that it's not in the way.
12-01-2015, 09:27 PM   #3
It stays on. The weight is primarily in that expensive glass more than the sturdy ring.
It's a great lens, enjoy!
12-01-2015, 09:35 PM   #4
UncleVanya's Avatar
Thanks a lot.
Correct. The entire point of that system is to allow you an easier to carry option than the traditional ring by having only the foot removable.
12-02-2015, 04:58 AM   #5
Enjoy the "heavy" lens. I always found (and swear by) a weighted lens/camera. It gives more stability to your photos when hand-holding. When you shoot with weight while using a long lens you will be in a better position to get that shot compared to someone doing the same with a much lighter lens and camera. It may be the "old school" photographer in me that claims that but it is def an advantage and will allow you to get away with a slower shutter speed compared to a lighter lens and camera. Of course tripods will solve that but weight is an advantage when you do not have a tripod or its not feasible to use one. I love my Tokina AT-X Pro 80-200 f2.8 which weighs in at 1350g (3lbs), the "tank" is solid and heavy. I tuck my elbow in (against my body) for support and allows me to "cheat" the Shutter-speed inverse focal length rule of thumb.
k-mount, lens, metal, metal band, pentax lens, question, slr lens, tripod
Newbie -- Help requested -- lens won't come off rw2mlt Troubleshooting and Beginner Help 32 09-14-2011 06:07 AM
Manual lens stuck on K-X, won't come off bklonoski Pentax DSLR Discussion 4 09-07-2011 11:35 PM
Does lens hood come with DA 18-250mm? Ron_Man Pentax Camera and Field Accessories 4 06-05-2010 10:07 AM
Question on the new DA* 60-250mm F4 ismaelg Pentax SLR Lens Discussion 2 04-21-2009 10:03 AM
Bailin' on the 60-250mm dkittle Pentax SLR Lens Discussion 13 10-08-2008 11:08 AM
All times are GMT -7. The time now is 06:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
