Hi there,
just two weeks ago I've purchased used lens as from title, from ebay seller. Price was 34€ + 7€ shipping
First test showed very pleasing results regarding IQ, color and sharpness. But, soon I've discovered that on 200mm position maximum object distance to be focused is approx 10m when focus ring hits the infinity stop. No infinity focus.
After first shock, visited every forum that can give me more information about infinity focus adjustment, but no luck with this Tokina version. Search took almost two weeks, when I finally found one post on chinese DIY forum where exactly my type of Tokina is disassembled for glass cleaning. After a while, I've managed to disassemble the front tube off the lens and get access to front lens focusing group. Then I figured out that only contact zoom ring has with front lens group (wich sits on a focusing helicoid) is via front tube that holds the nameplate ring. Three tiny flat screws around tube are giving friction contact between that tube and focusing helicoid (see pictures).
So, to adjust lenses for infinity focus, set zoom ring on infinity position and just loosen those three screws (just loosen, a one turn is enough, if you unscrew it, they are so tiny that it will be prety hard to get them back in place) to discard tube contact with focusing helicoid. When screws are loose, return zoom ring to a bit closer than infinity mark (notice that you won't move focusing helicoid now because there's no contact with tube), and then fasten just one screw, attach lenses to a camera and try to get distant object into focus by turning focusing ring. If focus is still not achieved, repeat the process (loosen the screw and return focus ring further from infinity, tighten it again and test) as many times it takes to get real infinity.
Once you have infinity focus, loosen the screw again, try not to move helicoid by any other mean when turning zoom ring to a infinity mark. Then tighten all three screws back - you have done infinity focus adjustment.
For the same thing on a zoom short end (80mm) I didn't have to align anything, so I can't tell how it could be done.
Hope this will help to someone like me...
