12-13-2015, 03:59 AM   #1
lens screwdrive gear broken
I never thought this would happen to a Limited (given how I only reserve opportunities to use it) but my FA77's screwdrive gear just broke. I had it checked by a local technician and he showed me the gear linked to the screw shaft has broken. Now I'm looking to have it repaired. Not sure how much it will cost though....
How often does this happen to screwdrive lenses? Could it be because newer cameras have faster torque/spin with the screw? I thought SDrive lenses are much hardier than SDM ones... especially our dear Limiteds
12-13-2015, 04:16 AM   #2
I know that it's not comforting to hear that you are the only one (for a limited) that I have read about. I have a 16-45 lens that one of the focus gears has broken (in the lens body) - that I need to get repaired. So, it does occur, however it is certainly not something that is very prevalent.
12-13-2015, 04:28 AM   #3
QuoteOriginally posted by Alizarine Quote
That happens especially when something prevent the AF ring to rotate and the camera is trying to focus, leaving the camera switched on and put it into a backpack, or someone is holding the AF ring opposing the force from the camera AF motor.
12-13-2015, 10:40 AM   #4
I got a quote from precision as something similar happened to my 43mm (more likely to have been caused by some sort of manufacturing defect, but the lens was already out of warranty), and they wanted around $150 for it.
12-13-2015, 05:30 PM   #5
that's the odd thing, I never let such happen. It was only after I stored it sideways one time that the screw started making strange clunky sounds while turning. Soon enough, it stuck up. Never happened with my cheapo kit lens that's been tossed and rolled on by other stuff in the box, it still works flawlessly.
Thanks Adam for the heads-up on possible repair costs. Looks like it can't be done DIY (I don't have tools too)
02-18-2016, 08:39 AM   #6
I have the same problem with my 43Lim and FA 85/1.4 now. If anyone had solve this problem and find solution?
Pantax service didn't sell parts and insist to give them whole lens for repair. Price will be much higher than for part only...
02-23-2016, 01:11 AM - 1 Like   #7
QuoteOriginally posted by Olek Quote
I managed to find a great local technician (in Manila) who was able to repair my lens for half the cost of sending it to Pentax for repair. Also, I wouldn't recommend doing it yourself even if you have the parts due to the very intricate detailed nature of the parts inside Limiteds - especially the 43 and its size - unless you have some experience tinkering with them and/or are confident enough with your own repair skills.
When I sent my lens to him he had to look for the part and it took some time, about three weeks. I think some parts for Limiteds are not standard across Pentax lenses so what works for one lens might not for another.
broken, gear, happen, k-mount, lens screwdrive gear, lenses, pentax lens, screw, screwdrive, slr lens
What does a Screwdrive Converted Pentax DA* 50-135mm F2.8 lens sound like? OnTheWeb Pentax SLR Lens Discussion 3 06-08-2014 01:48 PM
Broken screwdrive AF on FA77, where to get parts/have lens repaired? wysz Pentax SLR Lens Discussion 2 08-07-2013 09:56 PM
Pentax KX, broken tooth on a gear jsuln11 Pentax Film SLR Discussion 7 02-23-2013 05:30 PM
Modifiying lens EPROM to desactivate SDM and use screwdrive :D aurele Pentax SLR Lens Discussion 3 12-21-2012 06:22 PM
Lens is broken: broken mount nemo9439 Pentax SLR Lens Discussion 4 08-27-2010 09:52 AM
All times are GMT -7. The time now is 08:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
