View Poll Results: Do you use a protective filter on your lenses?
UV 2624.07%
Protective 87.41%
No 7468.52%
Voters: 108. You may not vote on this poll
12-16-2015, 04:44 PM   #16
PEG Moderator
Kerrowdown's Avatar
I run naked lenses except for wearing hoods at all times.
12-16-2015, 05:57 PM   #17
I use UV , skylight ,81a sometimes carryover from the film era formost for protection and then for haze reduction and contrast in B & W. A lens hood (plastic or metal) where ever possible and if no Polarizer port A Rubber collapsable so PL can be adjusted.
Has saved at least a couple of lenses from total destruction and more from some damage to front element and front filter ring over the years.
12-16-2015, 07:37 PM   #18
tromboads's Avatar
Yeah filters ROCK! Lens caps are so boring!
When I'm in the jungle, knowing I can just wipe the crud of my filter is much easier then worrying about ensuring the front element is always pointed down / putting a cap back on / carrying a cap. / caps are just annoying.
Unless of course I'm using the K1000, ...
12-16-2015, 08:08 PM   #19
clackers's Avatar
Lens caps for me.
Easier to remove prior to shooting than a filter.
12-16-2015, 08:17 PM - 1 Like   #20
gmans's Avatar
QuoteOriginally posted by Kerrowdown Quote
I am glad you included lenses in you sentence.
Hood winked all the time for me.
12-17-2015, 04:47 AM   #21
QuoteOriginally posted by LoneWolf Quote
This a relic from my film days when a UV filter was normally recommended to prevent an excess of UV light hitting the film
Many of my lenses find their way onto my film bodies from time to time, so it's still useful for me.
12-17-2015, 07:47 AM   #22
Insanely humble
savoche's Avatar
Filters for protection? No.
12-17-2015, 12:34 PM   #23
Yo dawg! I heard that you like protective so we put protective filter on top your protective lens coatings so ur protective while you shoot.
12-17-2015, 02:07 PM   #24
fwcetus's Avatar
[Another poll that I can't answer due to limited choices...]
Yes ("UV" filters may be used on certain lenses exposed to more hazardous conditions),
and
No (not on most lenses most of the time).
12-17-2015, 02:10 PM   #25
F/8 & Somewhere
TedH42's Avatar
QuoteOriginally posted by fwcetus Quote
and
This, exactly.
12-17-2015, 02:13 PM   #26
monochrome's Avatar
No, not for general protection. Lens cap and a hood is sufficient.
I have a stack of 40 or 50 UV And Skylight filters from my days of buying and selling lenses. I keep the Asahi filters from the 60's and the nice SMC and Ghostless separate, and a set of the colored filters available for film in 49, 52 and 58. I don't have any larger filters, and the large front elements are generally on the expensive lenses.
12-19-2015, 01:06 PM   #27
To be noted that a filter always degrate quality. It add more flare artifact, it decrease contrast, resoltion, etc. Filter are also know to deteriorate bokeh. It can be visible or not and highend filter help with that sure. It is comon to see somebody that complain of the quality of picture they get to then discover it was due to a low quality filter that got in the way. Recently I have a thread just about the terrible bokeh a guy got and the root cause was the filter.
You have to factor the cost of the filter, the occasionnal picture where the filter ruined the picture due to flare and to count all the occasions where a filter will not help the lens at all. A shock can prevent the lens from focussing correctly anymore, change the the precise alignement etc meaning you lense is still broken anyway.
There also the issue that front lens elements from Pentax are very easy to clean while most filter are quite difficult because they don't have the same quality of coatings meaning the things you didn't manage to clean on the filter are going in the way of the picture too.
A hood already does 90% of what a filter does in normal conditions and it actually improve picture quality.
The best way to not get issues with your lenses are:
- To put the lens cap when you don't take photos.
- To ensure you camera and lenses are in a protected bag when not in use.
- To ensure you always have the strap and the camera secured
On the occasion a filter may help like protecting from sand/wind/water but you'll have to consider that if this may deteriorate the lens, it will deteriorate the filter too so you be logical and consider that in that last case you may buy new filter from time to time so their deteriored quality doesn't get in the way.
12-20-2015, 12:19 PM   #28
and
Same here, and I always use a lens hood.
12-20-2015, 12:59 PM   #29
virusn3t's Avatar
Nah, i use the hood lenses as protection and offensive weapon if needed, cheap UV maybe can add problems rather than benefice, several good UV and im halfway to a new lens... So far, i tried to not drop my camera with or without lenses and put caps every time i take the lens off the camera, all my lenses are in good shape... (knocking on wood)
12-21-2015, 06:22 AM   #30
LoneWolf's Avatar
QuoteOriginally posted by virusn3t Quote
Your are obviously very good at not losing or misplacing lens caps.
I am still annoyed about dropping the Pentax one for my pancake 40mm because I had not screwed it on properly. So far I have not been able to get a replacement. Boo and lots of Hoos.
filter, k-mount, pentax lens, slr lens
What do you use to tether your K3 to laptop? Do I have to spend 50 bucks on a Tether? CeciProAm Pentax K-3 8 02-05-2015 05:19 PM
Do you use your 50mm on APS-C? yusuf Pentax SLR Lens Discussion 43 04-23-2014 10:22 AM
What kind of lenses do you use on your 645D? slackercruster Pentax Medium Format 40 06-02-2012 05:50 AM
n00b question: Do you use have a UV filter (at minimum) on all your lenses? innershell Photographic Technique 35 08-14-2008 03:37 AM
Do you use a Protective Filter? mwcfire Pentax Camera and Field Accessories 13 03-05-2008 12:50 AM
All times are GMT -7. The time now is 10:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
