Originally posted by Dean Bradshaw I think I had seen online that this lens had frequent issues with stuck aperture blades, but the rattle threw me off...really sounds not quite right...so glad to hear that is not an issue.
I've had a quick look (it's 23:15pm in Perth, so no working on lenses right now for me) at your pictures of the disassembly. I notice my version looks different to this. Mine is a PK mount and has 3 black screws on the black part of the rear of the lens, but 5 silver screws holding the mount on itself. It looks like you're version has just 3?
As said, I haven't gone any deeper than this yet, so I'm sure your pictures will still be very helpful. Hopefully I'll still have some time in 2015 to have a closer look at this lens.
i have/had three copies of this lens, none had sticky aperture problems, but one of 'em does have haze inside the rear lens group.
mine are vivitar 28/2 lenses, 22xxxxxx serial, 3/5 screw configuration, not like the nikon-mount lens in the pics.
however, the rear lens group does indeed unscrew all as one unit... remove the three screws in the black mount, and you can just fit a lens spanner wrench onto the top ring.
the entire group should unscrew, but i suppose that there is a chance that only the top ring on the group will loosen.
it's pretty straightforward, but of course you'll need the spanner wrench and preferably some jic screwdrivers.
i tested this glass for field curvature in landscape photos, on the a7r, if you want to see what it looks like stopped down:
28mm camera lens comparison, on the Sony a7R: first round
on ff, this lens changes radically from f/2 to f/10, it's like night and day; rather weak wide open, but as you can see above, it's respectable at f/10... just a hint of a wavy focus field, so it's not quite a match for the pentax-m 28/3.5, but then most lenses aren't... here it is at f/2.8, in about the worst possible lighting conditions, shot with the Sony a7R, iso10000, Vivitar 28/2.0 at f/2.8, ambient lighting only, no flash.
