12-20-2015, 02:01 PM   #1
Digitiser of Film
BigMackCam's Avatar
Advice needed on screwdrivers and oils for lens servicing
I'm taking my first steps into basic lens servicing, concentrating on some older manual prime lenses as they seem to be the best place to start.
I already have:
- good quality adjustable lens spanner / wrench
- decent rubber lens ring removal tools
- lint-free microfibre cloths
- high quality isopropyl alcohol for cleaning jobs
- rubber work mat
To this, I need to add some decent screwdrivers and some basic oil & grease for lubrication jobs.
Could any of you recommend a practical set of sizes for the screwdrivers I'll need (slotted and phillips)? Also, which oils / greases will get me started? I'm not looking to have every eventuality covered at this stage - just a basic selection to get me going. I'd planned on buying from micro-tools...
Finally, are there any other must-haves that I've overlooked in terms of tools and supplies?
Thanks in advance
12-20-2015, 02:21 PM   #2
jatrax's Avatar
Any good set of micro tools will give you good slotted drivers. However, many (most?) lenses use JIS screws not Philips. Philips is very close but just off enough to strip out JIS heads if you are not careful. So get a set of JIS drivers.
In addition:
A good magnifier lens and a lighted one on an arm is ideal
dental picks and other probes
tweezers of various sizes
Plastic part bins
Ziplock bags, some lenses are better dissembled inside a bag so when the springs go flying they are not lost
Acetone is sometimes used for cleaning and to clear glue
Fine paint brushes
rubber air blower
12-20-2015, 02:22 PM   #3
Don't forget that the "Phillips" may be JIS!
12-20-2015, 02:28 PM   #4
Not Phillips nor slotted (though the latter may occasionally be useful) but JIS (Japanese Industry Standard) drivers which are Phillips-like but which will not strip the screws. Use a Phillips and you will soon be swearing in impotent rage. There's something about them which does not suit these screws at all.
What I bought: http://www.amazon.ca/gp/product/B004PGO1T6?psc=1&redirect=true&ref_=oh_aui_detailpage_o04_s00
12-20-2015, 02:49 PM   #5
Micro-Tools Europe Tools | JIS-Type
12-20-2015, 08:21 PM   #6
For some reason, Micro-tools in the US does not stock JIS screwdrivers. A good place to try in the US is the Society of Photo Technologists web page. Scroll to the bottom to see screwdriver info . https://www.spt.info/
12-20-2015, 09:22 PM   #7
pacerr's Avatar
Maintenance and Repair Articles - PentaxForums.com
12-20-2015, 10:24 PM   #8
Otis Memorial Pentaxian
QuoteOriginally posted by lytrytyr Quote
Almost assuredly if the lens was made in Japan.
12-20-2015, 10:50 PM   #9
QuoteOriginally posted by dcshooter Quote
Nyogel or another synthetic grease for the helical.
Which grade Nyogel do you recommend? I have a couple of lenses needing helicoid service and have read varying opinions regarding greases. I finally bought a small tub of Helimax-XP from an eBay vendor, but would like a backup solution in case that does not work. (Will be used with a mix of metals including some former Soviet lenses.)
MicroLubrol? HELIMAX-XP? Camera Lens Telescope Optical Instrument Focusing Helicoid Grease w/ PTFE 1oz 28g
Very few lenses will use any oil.
This is very good information that should be taken to heart. For most lenses, if you find oil in the iris diaphragm mechanism, it has migrated there from somewhere else. The automatic diaphragms found in most lens made since the late 1960s are designed to run clean and dry.
12-21-2015, 07:16 AM   #10
Oldbayrunner's Avatar
If your near a Home Depot in England, or check Ebay online, take a look at the Husky precision screw driver sets, also the Husky pick and tweezer set. I have been using them without stripping the heads on any screws I have used them on many a lens and camera without stripping any screw heads. Of course care does need to be taken if the screw is exceedingly tight or has some type of lock tight on the threads. Also if you buy them from Home Depot they are covered under a Lifetime warranty, which means if the tool fails you can go back to home depot and they will automatically replace the item without a receipt or proof of purchase.
12-21-2015, 09:17 AM   #11
I prefer the lighter grades (774L, 744), but it really depends on the size of the main helical thread. Smaller threads will take a lighter grade in order to achieve the same stiffness.
Do you have any purchase links for this? I've decided to sacrifice my 50/3.5 Industar (inasmuch as if it should come down to not being able to put it back together again, it's the lens I can most afford to lose) and see if I can do this CLA thing. If that's successful, I'll look for a heavily dusted Takumar or two to attack.
12-21-2015, 10:13 AM   #12
Digitiser of Film
BigMackCam's Avatar
Thanks for the very useful responses, all. I've ordered a small set of JIS screwdrivers by Vessel - they seem to cover the sizes I'll need and are of good quality. Great info also on the use (and non-use) of oils and greases. I'll start off with some light grade grease and work from there. As for other recommended equipment, I have a few of those things already, but the plastic tweezers sound useful. I have an unlit magnifier that I use when soldering, so I'll use that to begin with along with my desk lamp. Great stuff, thanks again!
12-21-2015, 12:35 PM   #13
Thanks, this is very useful.
12-21-2015, 02:31 PM   #14
Digitiser of Film
BigMackCam's Avatar
Actually, since we're now talking about Soviet lenses, I'm guessing that the JIS screwdrivers won't be ideal for the Soviet screws (the cross-head ones, at least)? If that's the case, is there a specific type of screwdriver set I should look for to cover these?
fluid, jobs, k-mount, lens, lenses, oil, oils, oils for lens, pentax lens, quality, screwdrivers, screwdrivers and oils, slr lens, tools
Beginner and need advice on Lens for Aurora shooting. GAZ_XB9R Troubleshooting and Beginner Help 21 02-11-2015 11:16 PM
FA* 80-200 f2.8 focus issue... ADVICE NEEDED for lens adjustment! mattieyp3 Troubleshooting and Beginner Help 24 09-17-2014 08:30 AM
Advice needed on recent purchase of damaged lens davidreilly3207 Pentax SLR Lens Discussion 12 12-03-2013 07:44 PM
Advice on a 3-4 Lens-Kit for a beginner needed Ragnar Troubleshooting and Beginner Help 10 05-30-2011 12:43 PM
Serious Advice on lens needed netuser Pentax SLR Lens Discussion 32 05-03-2009 12:50 PM
All times are GMT -7. The time now is 06:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
