Originally posted by MikeV Thanks for the comments.
Some understand the problem some didn't get my need requirements.
No...I've never seen anyone change from one lens to another lens in the time it takes to spin the ring on the zoom lens, so multiple lenses are still out.
The zoom ranges noted, and my comment about trying the current lens at 50mm and 60mm to see if the other (60-250 and similar) Pentax lenses could be used seemed to say that these wont work as the short end is still too long. I did really want the 60-250 Pentax lens...it just wont work for my uses.
Use a tripod/mono-pod...that person didn't read my comments..! Speed is required. By the time I put even a mono-pod down, get the height adjusted, attach the camera, that shot plus many other picture possibilities have long since passed..! Plus, I'm not that shaky yet..! Again, my other cameras do well.
Multiple cameras are out because of traveling considerations. Much difficulty there. This is why I'm asking about adjustments I may have missed within the camera.
Yes, I do use JPEG for everything. I guess this may be more of a hindrance with this camera vs. lenses as desired than other combinations. I've just not wanted to spend a ton of time working on 75 to 150 keeper pictures per outing.
And yes, I do understand the word "sharp"...as in detail, not color, depth of field, etc.
I doubt that the K3 "should" be sharper than the 6D Canon, but I'd think it would be nearly similar, much like my A 77II. I don't think an APS-C sensor can match full frame sensors for detail acquired.
At least for now, I guess this camera is relegated more to stationary object shows where the cars, planes are just sitting. Too bad, I had great hopes for the K3 at the various car and bike races, RC car and plane racing and air shows where there is flight. It still requires a better lens even for stationary pictures. I did have reservations about the "Tamron"/Pentax lens, but it does have the reach I need..!
One statement from above...is there lens micro-adjustment in this camera that I missed ? I'll go looking...thanks for the reminder.
Thanks again for taking the time to answer.
Mike
P.s. - Boris, clackers and a couple others, good reading, thanks
Mike
In reading this last reply I think there are two things you need to consider. As I initially commented, you need to review and look at the JPEG settings. There may be a lot to consider and learn from in setting the jpegs.
Secondly, if you are using this camera and lens for action shots, consider also turning SR off, unless you are very good at panning, SR can actually lead to blurred images due to the "jitters" in your motion.
Also check your settings, including auto ISO and exposure. The camera will try to. In full auto mode, meet the MTF curve for the lens by first boosting ISO, if it cannot get exposure with ISO it will then open the lens up, followed lastly by dropping shutter speed.
I shoot manual everything. Or if there is some specific DOF and shutter requirements I will shoot Tav mode and let ISO float
It would be really good if you could post photos so we can see what your issues are, along with the exif data. People here are willing to help, but some will come on a bit strong and negative if you criticize the gear and do not post photos. We get "trolls" from time to time that just come here to down talk the gear, and people take offence after spending a lot of money to hear someone else slam their decision.
One last note, you list that you have a lot of similar gear, why did you buy the same in Pentax? What was missing in the other systems? Just curious
