You mentioned: "...because i don't know how long the 135mm can be, maybe long enough"
But you have a 50 mm lens. Comparing the angle of views for 50, 135, 200, and 300 mm lenses one can conclude followig:
-- with 300 mm lens the child can be 5.65 times farther away, and yet yield similar size image as w/ the 50 mm lens
-- with 200 mm lens the child can be 3.75 times farther away, and yet yield similar size image as w/ the 50 mm lens
-- with 135 mm lens the child can be 2.5 times farther away, and yet yield similar size image as w/ the 50 mm lens
So (for example) take a picture of a child w/ the 50 mm lens at a known distance, and then you can calculate what the maximum distance would be to yield similar size picture with the zoom at its longest focal length. But the perspective wll change--at longer lengths the sense of perspective will flatten (be significantly diminished).
