The FA31 is only really matched by the K/A 50mm f/1.2 for bokeh quality, the FA77 and FA43 have different bokeh characteristics from the FA31. Overall colour and contrast are practically identical with the FA limited lenses, though the FA31 is a standout as its resolution characteristic is more consistent across the frame than the FA43 and FA77 at wider apertures,
especially on full format. At f/4, optically there is essentially no difference between the three limited lenses, apart from the missing aperture blade on the FA43.
I'm not sure if my experience on full format with the FA43 really translates - i'm using the LTM version of the FA43mm f/1.9 on the Leica M8/M9/Monochrom - and I have found it is very different from say the Voigtlander Nokton 40mm f/1.4 or the Rollei Sonnar 40mm f/2.8. Also one little known fact: the LTM version of the 43mm f/1.9 has an extra aperture blade - 9 instead of 8 for the Pentax FA version, this makes the bokeh a bit smoother at smaller apertures.
Leica Monochrom - Pentax LTM 43mm f/1.9 Special
On the Leica M9 the LTM 43mm f/1.9
Special takes a bit of getting used to, but that is perhaps an
unfair critique as I'm more accustomed to using fast 50's on RF cameras. The fact that I'm using it on Leica rangefinders which on no account come with 40mm framelines makes things a bit awkward*. Though on the APS-H format M8 it gives the FOV of a 55.9mm lens, which is somewhat less awkward with the RF framelines.
*Pentax does make an external brightline viewfinder that comes with the LTM 43mm f/1.9
special. However, I'm not taking the risk of losing it: So I use a 40mm viewfinder from Voigtlander instead.
