Originally posted by pintax Those pictures are from ephotozone reviews. They may be a bitmisleading. The Samyang shot is at f8. The Pentax 16-85 is shot at f6.3. Moreover, the 16-85 shot seems more front focused. Look at the flower bed. They're equally sharp in both images. It's only the back building that's sharper in the Samyang shot.
Also consider that according to ephotozone's own "imatest" tests, the DA 16-85 is sharper, at 16mm, than the Samyang 16mm f2. Here's the graph for the DA 16-85:
And the graph for the Samyang 16mm:
I suspect that, in practice (assuming good technique), you're not going to see any significant difference, in terms of sharpness, between these two lenses. What you might see is better contrast and color rendition out of the DA 16-85, thanks to the superior anti-reflective HD coating technology used by the Pentax lens.
I would go with the DA 16-85 first, and then supplement that lens with various primes (or longer or wider zooms) as one's budget and needs dictate. The zoom will give you quality not only give you quality at 16mm, but at 17mm through 85mm as well. True, the zoom is "slow" in terms of aperture. But that's what primes are for. The DA 16-85 with a couple (or more) of fast primes constitutes a pretty solid, no-nonsense kit.
