Originally posted by timb64 So to summerise in less than eleven words,its weakness is in fact its main strength,what patent nonsense!
NO, it's weakness is not a weakness in many shooting situations, and it's strength is it's range. From 18-50mm, it stacks up with any lens out there, 50-135 you have to use it for a specific type of shot.
What is often shown as was the case here, was that those who summarize in 11 words, often display that they couldn't understand what was said.
Often a picture is worth a thousand words....
How would this image be improved by having sharper edges?
And if you can't improve on it by using a much more expensive lens, why wouldn't you go for the cheaper option?
The edges are so out of focus, the sharpness of the lens at the edges makes no difference. Changing to a better lens doesn't improve the image, because in the center, where the subject is, the sharpness is excellent, even on Photozone's tests. Are you starting to get the hang of this? Not every picture benefits from having a lens that is sharp edge to edge.
If you buy something for what it does, it will always do that thing. This is a lens you can buy for what it does, just make sure you want what it does. If you want more than what it does, buy something else. Personally, I'm quite happy with what it does. And I generally don't think much of folks who criticize it for what it doesn't do. Every lens has stuff it doesn't do. If we start dwelling on what they don't do for every lens. no one would ever recommend anything.
The above is a macro image so the fact that it's shot at 135mm makes no difference. You can do this same image with a 16-85.
With images like this one,
You can't match it with a 16-50 or 16-85. It's 135 using every bit of reach and shot to the strength of the lens. In fact I doubt you're going to match this image better with any lens you choose. The lens needs to be WR, it needs to be easily hand held, and it need to be relatively small to fit in a very compact case for easy management in the boat Despite all the nay sayers, the lens is the best lens for some applications. And that's what I look for in a lens. Does it give me something I want, that no other lens gives me.
For what it does, it's best in class, for $300.
