I've got a 200mm ƒ3.5 that I purchased new about 1979, plain K-mount, used it on my film bodies, never mounted it on my digitals,
Has a forward ring that turns about 300-degrees to go from infinity to just under 2-meters
Rear ring turns about 90-degrees to go from infinity to just under 1-meter, combined I think they get you to about 0.5-meter.
58mm filter size on it.
I don't have any strong memories of using it one way or the other, but a bit fiddly to use with the two focus rings, for most use, had to make sure you had the front one at infinity, or you could not focus at distance.
Seems like a solid piece of workmanship, screw-in metal hood seems a bit short for it though, and the aperture lever on the rear has always looked odd to me, no fixed guard on it like a Pentax lens would have, and the lever looks long, bit afraid it would stick too far into a body, never saw any sign of trouble from it though.
