Originally posted by BrianR Nor did I. Not as it's main function at least - I embrace its fishiness in most circumstances. However, it might make leaving a rectilinear wide angle at home a little easier to tolerate if the fish can substitute in a pinch with the right tools. So I'm following this discussion carefully
Exactly... and hence all my work at defishing.
I did spring for the DxO ViewPoint while it was still selling for $39. It can do a better job than what can be accomplished in LR with lens correction, but mainly it can do it more quickly. It also is much easier with shots that aren't simply distortion or vertical/horizontal issues. BUT, it only works on JPGs or TIFFs! I shoot DNG, so if I'm in Lightroom and want to use ViewPoint, it has to convert. A bit of a pain...
Still, it gives me confidence that I can leave my Sigma 10-20 at home and use the DA 10-17 as my UWA and whimsical lens.
Now I have something of a gap in field of view between the 10-17 FE at 17mm and my DA 18-135 at 18mm. I could see where the DA 16-85 would make a better partner.
Will the madness never end!?!?
