There is much confusion surrounding the Vivitar and Soligor T4 and TX mount system. Because the only K-mount adapters made were for TX lenses, many K-mount camera owners have used M42 adapters to use T4 lenses with M42 mounts. This means losing auto diaphragm and meter coupling. I did some tinkering with my T4 lenses and a TX K-mount adapter and succeeded in modifying the lenses to function with the TX K-mount adapter. The modification requires cutting away a small portion of the backplate of the T4 lens to allow the TX adapter pin a wider range of movement. This does not impair the appearance or normal operation of the T4 lens. See the attached images for before and after views of a modified lens. The backplate is secured by three small screws and can be easily removed so that the cutting work does not harm the lens. I used a small jeweler's saw, but a Dremel tool would work too. The metal is soft aluminum and cuts easily. Remember to remove the small diaphram linkage pin from the backplate before cutting, so that it does not get lost. Reattaching the backplate is a bit tricky because the diaphram linkage must be properly engaged, but with patience and a few tries you will succeed in making your Vivitar or Soligor T4 lens usable with a K-mount adapter, providing full aperture viewing and metering.
