I'm joining the group of "carry as little as possible". I once made an excel sheet with all the weights i was going to carry. What i dare to state after that:
- nothing is lighter than your plastic fantastics - except my 40mm xs :P - and weight is more important than size.
- accessories are important: a common camera bag is likely to constitute 30-40% of all your camera gear. that's why i just used clothes and waterproof outdoor bags for protection. plastic fantastics are also cheap, so don't worry
- accessories are important 2: don't take long cables (cut the power cable, replace the usb cable with a 12g card reader) and heavy power adapters with you.
- if you just plan to shoot on occasion while traveling, i. e. arriving on a nice spot, i. e. not a planed shot at sunset taking 3 hours of preparation, then may leave your tripod at home. Use your bag, your environment instead (i often use my wallet and a rock/wall/chair). and if your fellow traveler is as patient as any fellow traveler is, you don't want to use the tripod anyway
of course if you plan to use your filters extensively, forget my opinion. although a tripod is basic for photographing its not for traveling.
- If you have the 55-300, you'll hardly ever need your 50/1.8.
- crop and stitch! if you have your 35mm and you desperately need 20mm.... stitch. if you need 10 and you only have your new 15mm... stitch.
- don't ask what you want to take with you, but ask what fits in your backpack with a limited weight, e. g. max. 20kg incl. food, water, clothes, etc.
so 15mm, 35mm, 55-300mm - 800g?
