Originally posted by normhead Having light scattered on your image where it's not supposed to be doesn't affect micro-contrast?
I'm not sure what is meant by "having light scattered on your image." Are you sure you're not confusing chromatic aberration with spherical aberration? Spherical aberration will most definitely affect micro-contrast, as is easily seen in any image from a soft-focus lens.
Originally posted by bobbotron This thread... is derailing
Well, not necessarily. Because the issue of whether CA correction in post has any affect on image quality does actually have quite a bit to do with the topic of best bang for buck lenses, and here's why: CA correction in post is much cheaper than optical correction of CAs. So conceivably we can better glass (in terms of resolution, contrast, flare control, etc.) for less money if we are willing to accept software correction of CAs.
There are two broad attitudes toward this issue: that of the purists, and that of the pragmatists. The purists are offended at the very idea of any kind of software correction for lens' faults, regardless of whether it has any impact on "real world" image quality. The pragmatists only care about what actual images look like, and they'll gladly accept software corrections provided they don't have any real impact on image quality. Now while I wouldn't necessarily say that one attitude is "wrong" and the other "right" (it's all a matter of opinion), I would suggest that if you really want to get the best bang for you buck with lenses, you have no choice but to be a pragmatist. For those looking for the best bang for the buck lenses, the only question they should ask regarding CAs are: "Do they clean up easily in post?" If the answer is yes, there's no need to bother one's head about them.
