08-01-2016, 05:31 PM   #16
mgvh's Avatar
QuoteOriginally posted by m42man Quote
Definitely a big drawback. Be careful with your FL guess though, as if you enter a value much higher than the actual value you risk amplifying your shake.
Either enter the shortest focal length - which is totally safe, and SR will be at full strength when shooting at the wide end - or you can use a simple formula. I'll definitely be accused of boring everyone if I reiterate it, but, don't worry, the answer is the same for all your lenses: 100mm.
Agree about the 75-150 though - I've had one from new and it's certainly sharp enough.
(By the way, it's been a long time - hello again everyone!)
Welcome back!
Yes, you're right, and I do not simply average the short/long focal length. Someone once gave a very sophisticated formula for working out the best focal length, but roughly it came down to setting it about 1/3 of the way higher of the total focal range. So, for my 70-210, I'll usually set it at 100 or 120mm. For the 75-150, at 100mm. For the 80-200, at 120mm.
08-01-2016, 09:34 PM   #17
volosong's Avatar
QuoteOriginally posted by Swift1 Quote
The Pentax 24-50mm f/4 is a good lens.
And you're not getting mine! At least until I'm pushing up daisies. Got my copy off the bay in anticipation of the K-1. The more I use this lens, the more I fall in love with it. Small, lightweight, quality construction, handles well. Only complaint I can make about it is the lack of a hood.
08-01-2016, 11:17 PM - 2 Likes   #18
QuoteOriginally posted by mgvh Quote
Welcome back!
Ta!
I think that someone was me, and the formula was 2*min*max/(min+max). So you're just right with you're settings.
Just to repeat a warning for everyone: if you input more than 2x the actual focal length, you will magnify any effects of shake.
08-02-2016, 08:31 AM   #19
I like seeing the zoom recommendations in this thread!
As for SR settings. If one has the time to enter the focal length you're using the zoom at, picture by picture, is that ever wrong?
I can see how if one wants to be constantly and rapidly zooming around for reframing or other reasons having just one setting for a zoom lens would be an advantage, but if you have time to reset the SR to the zoom focal length you're actually using, why not?
08-02-2016, 09:48 AM   #20
mgvh's Avatar
QuoteOriginally posted by goatsNdonkey Quote
Yes, if you have time, then it is best to set SR to the actual focal length you are using.
Set your camera to remember the last location when you invoked the menu. Inputting focal length is in the 3rd panel of setup menu (on my K-30), so I just push the Menu button, go to the bottom to input focal length (so I go up one to make it go around to the bottom), and sets focal length. Not so bad, but when I'm in a hurry, I just use that proximate setting.
check, da, f2.8, focus, fun, instance, k-mount, pentax, pentax lens, quality, series, slr lens, vivitar
Normal or not? Focus ring on quickshift lens occasionally "sticks" (HD DA 55-300mm) Doundounba Pentax SLR Lens Discussion 11 04-18-2015 01:45 AM
"Click" in between "C" and "MF" mode on focus selector? K-50 maxwolfie Pentax K-30 & K-50 3 01-29-2015 04:19 AM
Program mode: "Auto" vs. "Normal"? PALADIN85020 Pentax K-5 & K-5 II 3 02-13-2011 12:22 PM
What "AUTO" on a manual focus Vivitar lens? emr Pentax SLR Lens Discussion 5 08-06-2010 09:56 AM
Definition of "Normal" according to Pentax Manual jsherman999 Pentax SLR Lens Discussion 37 12-12-2008 11:46 AM
All times are GMT -7. The time now is 10:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
