Originally posted by BarryE I have a DA* 16-50 which on balance I enjoy using, however it does seem to flare a little too much at times. I've mostly learnt how to handle this lens and how it behaves and I've had great results, except for the flaring. Yesterday I was shooting a misty stream with a low sun out of shot, perhaps about 30 degrees out of frame. I use the hood, and yes it's attached correctly. I also use a high quality UV filter, Hoya Pro1 - in tests this does not seem to cause any extra flare problems, it is down to the lens I feel. I know it's an issue for me and normally I manage around it, but sometimes I can't avoid the problem. Does anyone know if the 20-40 is more flare resistant ?
Thanks
What do you mean in tests? Did you actually shoot the same scene with an without filter and got the same flare issue? Or did you do so tests on a scene in other circonstances?
From experience, the best filter does terrible thing to our lenses. They increase flare a lot, but also in more subtle ways decrease contrast and resolution. Even if they are not too bad, they don't clean remotely as easily as the front lens element of Pentax lenses and a dirty front element/filter is also a very good reason for quite crappy results.
Adding filter to your lenses, reduce their quality in many occasion. Worse you may discover the problem too late when it is not possible to go back and take some picture without the filter.
The HD ltds are very resistant to flare, including the DA20-40 zoom. They are truely great for this kind of shoot, better than almost anything on the market because they combine prime with very few glass elements and outstanding coatings.
So yes the 20-40 would do much better, but if you plan to add a filter to it, don't even bother, you'll get flare anyway.
