I'm from Canada, so unfortunately it means most lens (used from US sources, ebay, etc) purchases are facing some steep 40% markups. Absolutely not worth it to pick up something new right now... New lenses are too steep for the wider, faster options right now; especially since my current preferences are moving to portrait/medium tele ranges.
Originally posted by pathdoc My idea of a holiday in Japan is sushi, Pentax, and a visit to the museum battleship Mikasa. Given previous experience of photographing on ships, wide angle is definitely the way to go - and by wide angle I mean 18mm would be too narrow and I would be planning two visits - one with my DA15 and a second after I had acquired a 12-24, if I wasn't happy with what I could take in. That, or a film/full frame body and my 17mm Tokina.
I accept that OP has to go with what he's got, but perhaps rental? Is there anywhere he's going that does that?
Canada has Henry's for pentax lenses, which doesn't offer pentax rentals (really its only Canikon)... otherwise I might as well have grabbed a 77 limited rental to fiddle with ages ago >_>
I've also kept an eye on their used lenses, but no 28mm M series has shown up (two are on Henry's right now, but they're the F3.5 variants)
Originally posted by dlh I wonder if you couldn't get the lens you want cheaper if you buy it in Japan. Visit Akihabara (Akiba Temple district) in Tokyo. Probably be able to buy two or three for what it'd cost you in the U.S. [Btw, I'd go for the 50mm F/1.4, myself. scratch that.] Re-read OP's msg, revised recommendation: Pentax smc DA 18-55mm f/3.5-5.6 AL WR.
Tokyo unfortunately will be near the end of the trip (4th last day), and was planned like that for souvenir purchases (don't need to lug things around). As much as the kit has access to 18mm, I'm not willing to give up the lower F stop for it (F3.5's just not good enough once the sun goes down and we're getting pretty far from the F1.4 of the 50mm).
