Originally posted by Weevil Yes please... I also asked @oneill to have a look...
Hi Weevil,
Further to my PM, I got off my iPad and I had a good look at your sample comparison images. This is a serious and unacceptable out of focus problem. I could not see anything in focus, but nothing had depth so I could see where it was focusing. judging by the small bird I would suspect front focus. I used my FA*600mm at F4.0 almost all the time, since about 1996, and although it was sharper at F5.6 or F8 it was still good wide open. When I did a LensAlign test on it I was right on the edge of the adjustment range at 9. Here are some suggestions that will take out the guesswork: You are using exceptionally good support equipment and I don't see many people using "long lens support" from Sunway, Hegnar, or Really Right Stuff. It makes a difference!
(1) Do a LensAlign test at a minimum of 50 feet (which they suggest for that lens)
(2) Definitely use their FocusTune software as it takes your subjective sharpness analysis out of the equation. Keep in mind that your DOF at that distance is just 4"
(3) Follow their "best practices" instructions, de-focusing between shots. THE SAME WAY EACH TIME
(4) Make your final micro adjustments and do a complete re-test.
When it is properly adjusted your wide open shots shout be acceptably sharp at 100%, particularly with the K3, and should be razor sharp at F5.6 and F8.0. If not there is something wrong with the lens. I don't think there is anyone in North America that will do a CLA on that lens. Eric said he will only do up to 500mm and I was told by Pentax that they do not have an optical bench to work on that lens in Canada, and I assume in the US as well, as when I dropped mine I had to send it to Japan, I don't even want to recall the freight cost, but it was more than the repairs..
It is older optical technology, but I always considered it "sharp" wide open. You are experienced, use best long lens practice and if the lens is properly micro adjusted, and not acceptably sharp, or if it can't be micro adjusted there is something wrong with the lens. As I mentioned in my PM I am using my DA560mm F5.6 a lot in the past year and like your FA250-600 it is incredibly sharp wide open and I think it has an edge on the FA600, not to mention the weight
If you want to talk send me a PM and I will give you my number.
Have a good one!
Murray
