Lots of sound advice in the first post.
Originally posted by mgvh I have a whole bunch of cheap lenses I need to get around to selling, but they all were a cheap way of helping me learn how to shoot and what I like to shoot.
This is a good point.
Most people start out without knowing which specialities will draw them most. Which is why I'd suggest to most people that they start out with one or two wide-ranging zooms - e.g. the kit lenses, or (for one step up and greater convenience) a decent superzoom like the Sigma/Tamron/Pentax 18-250, or (one more step up in IQ) the pair you suggested, 18-135 + 55-300.
After a while you will bump up against particular limitations. If you are often shooting wide, look for an ultrawide. If you are shooting a lot at the longest focal length, look at telephoto options. If you are frustrated at having to use a flash or high ISO a lot, look at something faster. If you are drawn to small things, try macro. If the image quality isn't quite what you'd like at your particular preferred focal length (e.g. portraits at 50-85mm), look for a better lens for that function. If you find your setup too bulky or obtrusive for street shots, consider a small prime.
When using a zoom, try to take note of what focal length you are using. This will help you to learn to compose a shot for a particular focal length - which is valuable knowledge if you later get a prime, or a zoom with a short focal range. It will also help you identify your preferences and future needs better.
The free program Exposure Plot is handy too. It can read the photos in a particular location on your computer and provide detailed analysis of the focal length, aperture, shutter speed and ISO of those photos. The results can be surprising. For example, if you find that 60% of all your photos are taken between 24 and 35mm at close to the maximum aperture, start looking for a prime (or f2.8 zoom) in that region.
Here's my experience.
I started with a Tamron 18-250 superzoom as my only lens. I loved the versatility (especially after constantly changing between two zooms on my old film SLR), and I was generaly happy with the IQ. For nature photography I found myself shooting often at either 18 or 250. So I went for both an ultrawide (DA 12-24, which is a fine lens, and I got it for a good price) and a long zoom (Sigma 170-500) for birds and wildlife. Both involved a learning curve - you need to develop extra skills for shooting either very long or very wide (handling in the former, and composition in the latter). And I got a nifty 50 (A 50 f1.7, then DA 50 f1.8) and a DA 35 f2.4 for low light, portraits, short DOF and general sharpness.
I could have stopped there and had quite a satisfactory and relatively inexpensive kit, covering 12-500mm.
But I got frustrated with the 170-500, which was a hit-and-miss lens. About the same time I scored a Kenko 1.5x tc and a Sigma 400mm f5.6 tele macro, each for an excellent price. So the 170-500 went to a new home. I also got a DA-L 55-300 as a light-weight versatile long zoom with significantly more reach and better IQ at the long end than the Tamron 18-250. By this time I had developed a taste for the extra sparkle of a really really good lens, so I have picked up DFA 100 f2.8 Macro, FA 43 f1.9 and FA 77 f1.8. And when a secondhand K-3 came with a DA 18-135, it was time for 18-250 also to find a new home.
Some things I've learned:
1. Move up to the best lenses you can afford as early as you can -
once you know what you like to shoot and in what conditions you shoot most. Most of us can't afford a bag full of Limiteds or star lenses - go for a small number of premium lenses (whether zooms or primes) in you main area(s) of interest. They don't need to be expensive - plenty of bargains particularly if you can live with manual focus. For autofocus, the plastic fantastics, for example, are great value. And if you watch the secondhand market carefully, or look for sales, some bargains will turn up even amongst Limited and * lenses: for example, I got my FA 43 on ebay for $A400 (about $US270 at today's rate), and it's a thrill every time I use it.
2. Post-processing is worth learning. Shoot RAW (or RAW+jpg) from the outset if possible, even if you haven't learned post-processing yet. You can come back and work on your best photos later. You can squeeze a lot more out of your shots with some judicious PP - in fact shots taken with less-than-stellar lenses often have more scope for improvement in PP (e.g. correcting distortion and increasing contrast and vibrancy). Yes, RAW files are big, but storage is cheap.
3. There is no free lunch with long lenses. The 55-300 is good, but the step up from there to something longer, faster and/or sharper costs plenty (e.g. $US1200 for the DA*300 f4) and generally involves a lot more weight and bulk (e.g. the "Bigma" 50-500 at 2kg). Everyone is chasing something better than the 55-300 but not too heavy and not too expensive - and there aren't many options. (My dream would be a re-release of the wonderful F*300 f4.5 at less than 900g, with a DC autofocus motor, HD coatings and WR seals for about $US800 - but it ain't gonna happen.) A more affordable solution is to try to improve the available light (e.g. with a flash extender, like this -
https://www.pentaxforums.com/forums/22-pentax-camera-field-accessories/256288...-extender.html ), so that you can use the 55-300 at f8-f11 where it performs best, without having to boost ISO to excessive levels (or use unduly slow shutter speeds).
4. Get to know your kit. That will help you get the most from what you have. Some people find the "Single in [month]" challenges (using the same lens every day for a month) a good way to do this. Test the AF accuracy of each lens and use the fine adjustment feature in your camera if necessary. For each lens, work out the conditions, the aperture and (in the case of a zoom) the focal length in which the lens performs best, and what its limitations are. Detailed reviews are a good start, but you need to determine for yourself, with your copy of the lens mounted on your camera. When is it sharpest in the centre? When is it sharpest at the edges? Do you need to stop down to avoid vignetting? When does diffraction cut in? What do you need to do to avoid (or use) flare? When are you likely to get bad CA? What is the bokeh like in various conditions? Can it produce pleasant starbursts? And so on.
5. Keep your kit under review - it's never really finalised. Your needs and interests change, more suitable lenses come along, and you want high quality in the areas you use most. But be warned: a review is not an excuse for lens buying addiction (LBA). Unless money is no object, be realistic about what you are using and what you aren't. If you are not using a lens and are not likely to use it, sell it - with the exception of rare and special lenses, lenses generally just depreciate more the longer you keep them. Unless you are a collector or a trader (each of which requires skill and commitment), there is a limit to the number of lenses you really need. That number will depend on whether you are a hobbyist or pro, how wide ranging your interests are, and how often you shoot. For me, as a reasonably enthusiastic hobbyist with a bias toward nature photography, I'd say the number is about 10, tops. (See my signature for the current kit - 8 lenses plus a TC.)
Here's an illustration of the last point. At present, I have two parts of my kit under review:
- I'm thinking about replacing the DA 35 f2.4 with something wider, because I don't use it so much since I got my FA 43 f1.9. I am trying to resist the FA 31 because (as fine as it is, and as nice as it would be to have the three princesses) I think I wouldn't use it enough to justify the high price. I don't find any of the 28s or 30s or the DA 20-40 Ltd very appealing, my 12-24 is very good at 24, and I'm pleasantly surprised at how well the 18-135 does at about 24-35mm.
- I'm thinking about replacing the DA-L 55-300 with a DA*60-250 f4 or DA*300 f4 (and using either with my TC if necessary). I'm leaning to the DA*300, because in truth I mainly use the 55-300 at 250mm or longer, it's often a stop too slow, and although the IQ is good it isn't up to the standard of the * lenses. The Sigma 400 f5.6 give me extra quality and reach - but it too is only f5.6, and sometimes it's too long. I'd find the Sigma 150-500 or 50-500 or the DFA 150-450 too heavy at about 2kg each, especially since I like to shoot handheld. The weight of the DA*300 is about the limit. Trouble is, the * lenses are very expensive, with the $A in decline. I'm wary about buying used because of concerns about SDM. The 55-300 has the virtues of being portable, lightweight and versatile - ideal for a walk. So in the end, I'll probably stay with what I've got for a while.
