norm koren went thru the color film vs. digital comparison in agonizing detail, years ago, provia 100f scanned at 4000dpi: "I estimate that a full-frame sensor with 8.3 megapixels would have resolution equal to 35mm film."
Digital cameras vs. film, part 1
it looks like you can sharpen the heck out of an 8000dpi scan, really drive the resolution numbers up, but the grain in the film is what hurts the pq.
he uses film to create some of the imatest backlit test targets? it looks pretty impressive blown way up, but gets killed by laser etching, and the edge of a razor blade:
Transmissive Chart Quality Comparison | imatest
---------- Post added 01-27-16 at 11:29 PM ----------
Originally posted by stevebrot Don't forget the M 50/1.7 which was used for comparison testing by the magazines of the time along with the best lenses of the day. I suspect that @osv mixed up the design goal of compactness with aiming for consumer lens quality across the range.
i'm defining consumer level by cost... compact typically means fewer elements, so it's cheaper for pentax to manufacture... pq was never a factor, retail pricing within a prime focal length was based on aperture.
however, minolta also labeled their consumer lineup as "celtic", and they reputedly cut some corners with the coatings... while a lot of the celtic lenses had the same optics as the more expensive glass, i don't think that celtic ever included fast glass... nikon did something similar with "e" series glass.
i'm no pentax expert, but if you don't want to call pentax-m consumer gear, how did they separate the lines, like the other companies did?
---------- Post added 01-27-16 at 11:33 PM ----------
Originally posted by stevebrot As for hitting the mark at 100 yards with my film camera...no problem.
i'd like to see any film shooter on this forum back that claim up
28mm, 2' target, at 100 yards, post it up
