Originally posted by Digitalis If you can find one of these you will be doing pretty well. The Pz-AF extension tube will work with any K mount AF lens however, AFAIK there is only a 25mm version and it is somewhat of a rarity:
Hi,
Kenko did a set of tubes that support all metering including auto focusing.
They are 36mm, 20mm and 12mm in length.
I had a set and at our last Cameraholics Fair I bought another set, brand new I might add for forty dollars! I could not pass them up at that price!
Regards.
---------- Post added 01-26-16 at 08:20 AM ----------
Originally posted by keanex Hey guys, did some reading on how to get macro shots on the cheap. I understand that going an extension tube method will require manual focusing, no problem. Is it just as easy as setting focus to manual?
Also the ones on Amazon all have poor ratings - any one in particular I should pick up?
Hi,
Have you considered a 50mm M series with a reversing ring?
Regards.
