Originally posted by vanchaz2002 Finally, I take it apart and it is not perfect ROUND shape. It's a bit oval shape, makes the mount does not fit both lens or camera, also the two aperture ring does not rotate their full range.
Does anyone has one of those or it's the rarest PKA adaptall mount ever?
If anyone has experience, can you tell me if Tamron can fix it as its obvious an manufacturing defect.
I have a PK/A mount for adaptall II which also needed repair, it looks as if someone tried to pry the camera off the lens without uncoupling. Due to the electronic apature coupling it is a little more fragile than a PK mount one (which I also have)
If you can get to the west end of toronto, go to international camera on the queensway in etobicoke, he has several
