Originally posted by noelpolar No digital image can exist in any meaniful way without processing. Simple.
Exactly ! The raw data from the sensor need to be "interpreted" in terms of a visible image by some sort of processing, you can let the camera carry the full responsibility for the whole transformation (i.e. , shoot jpeg), or carry the bare minimum ( i.e. , shoot RAW). If you choose the second option you have the freedom to apply essentially no further processing after the necessary demosaicing and conversion to the image format of your choice.
So it is indeed possible to obtain images with almost no post-processing, besides what is necessary to convert some raw analog signals into a matrix of RGB pixels. But i think the result would be pretty dull (and with otherworldly colours if white balance is also switched off
), no matter how expensive your lens and sensor are.
Of course i agree with the OP that to rely on the power of post-processing to compensate for "bad technique" is not a good practice, that maybe has become more widespread with the advent of digital imaging. However not every shot can be carefully planned and mistakes or adverse conditions can always happen, and the larger error margin we have thanks to heavy post-processing can help to salvage some shots from the trash...
