Quote: But really there as much here from variations and photographer technique than there is to lenses. Maybe even more.
Where are your lens comparisons Nicholas? It would be interesting in noting how you got better results... oops, you've got nothing. Just blowing hot air as usual. In absence of perfect, the imperfect will have to do.
Methodology used.
All shots taken from the same position with the same camera.
- I continued shooting with each lens until I got a good sharp image, some lenses required 20 images before they produced a sharp image... after 20 images I'm satisfied that this is as good as I'm going to get. But some produced a tak sharp image (for that lens) in the first five tries.
- All the images I relied on AF, which if you'll remember tested better for stationary objects than comparable Nikon or Canon cameras with over 95% of it's images in acceptable focus for stationary objects. Most cameras tested were below. I was looking for a little be better than "acceptable focus", I was looking for "the best the lens can do" irregardless of how many tries it took to get it.
-in the case of the Tak, I didn't have enough light to focus stopped down when I used it, and I end up doing 15 images with a small rotation after each image until I got an image that compared favourably with the DA 35.
- a two second delay (and subsequent mirror lock) was used
-as noted above, the sun went behind cloud while I was shooting, and later in the test came back out. I don't own any pro lighting that would have enabled me to completely control the light. Contributions are welcome.
-the camera was focused on the top of the greenish feeater in the middle of the frame, but in the end, the ragged edge at the bottom of the pixel peeper centre comparisons, disregard what Nicholas said about different focus point. If that feather tip was sharp as i could get it with that lens, I used that image. Sometimes the dude just doesn't have clue what he's talking about.
images were shot in batches of 5, and reduced to the best, then either used in the trial or reshot. Altogether there were four rounds. The DA 35 and 18-135 DA 18-55 and Tamron 17-50 produced good sharp images in the first round. The FA 35-80 and FA-J 18-35 in the second, it took 4 rounds to get the Takamur, but, that was as much because of lack of light coupled with manual focus as anything else.
All in all the test was quite simple yet still took most of an afternoon. Someone with endless amounts of time, a testing bench and a controlled lighting set up in their basement could do better, if you have that stuff, have at her.
However, I don't use a testing bench, controlled lighting or endless amounts of time. This is a real world test in real word conditions.
For a general walking around lens, IMHO, all lenses were acceptably sharp, but a few were exceptional.
