02-02-2016, 05:00 AM   #1
What was this lens used for?
I was given this lens. The pre-set aperture (10 blades) only opens out to F4,a bit limiting. Is this just a very cheap old M42 lens? Apologies for having two sets of images. I never seem to get uploads right and am not sure how to delete the extras.
PENTAX K-5  Photo
PENTAX K-5  Photo
Last edited by Skodadriver; 02-02-2016 at 05:21 AM. Reason: Wrong information about MFD
02-02-2016, 05:14 AM   #2
boriscleto's Avatar
The lens in the photos has a minimum focusing distance of 5 feet (1.5 meters).
02-02-2016, 05:16 AM   #3
QuoteOriginally posted by boriscleto Quote
You are right! must edit that.
02-02-2016, 06:12 AM   #4
It is plausibly a T-mount lens: the screw thread does not fit m42, although diameter is also 42mm. Don't force if it does not fir the M42-K adapter, you might need a T-m42/K adapter.
02-02-2016, 06:17 AM - 2 Likes   #5
dadipentak's Avatar
It looks like it was used to stir pancake batter.
02-02-2016, 06:21 AM   #6
QuoteOriginally posted by grahame Quote
It appears to be already fitted with a M42 mount. Certainly it screws into my (genuine) Pentax M42/K adapter.
---------- Post added 02-02-16 at 06:25 AM ----------
QuoteOriginally posted by dadipentak Quote
It is a very light lens and I would assume it is aluminium and the anodise has not stopped it from corroding.
02-02-2016, 07:05 AM   #7
QuoteOriginally posted by Skodadriver Quote
Good. I said that because I have one lens looks very like yours and mine is T mount.
02-02-2016, 07:13 AM   #8
Standard t-mount preset lens probably from 1960's.
How to use t-mount, preset lenses.
Hanimex is a reseller name, when you come across a lens like this it's always worth first doing a search on forum - just go to the third party lens reviews page and click on search - and then googling just the specs 105mm f4, or with other names of the era like sankor, mayfair, palinar, prinzgalaxy ........... to see what comes up. This lens seems uncommon I didn't bring up anything. Some similarity to this sankor lens though
Sankor ( series E, Mayfair etc...) preset, t-mount 135mm f2.8 or 3.5 Lens Reviews - Miscellaneous Lenses - Pentax Lens Review Database
which is a good lens actually so take some pics and check it out.
The external corrosion isn't nice but if its ok internally - no matter!
http://www.kenrockwell.com/tech/flashlight-test.htm
Update
http://forum.mflenses.com/palinar-tokina-100-4-m42-preset-the-smallest-tokina-t11952.html
02-02-2016, 07:39 AM   #9
Lowell Goudge's Avatar
it would make an interesting outdoor portrait lens, with the round aperture. clean it up and give it a try. it is a lens manufactured and rebranded for many stores to put their own front badge on, Not sure who makes them.
02-02-2016, 08:27 AM - 1 Like   #10
In a word, yes!
Apparently made by Tokina:
FS - Tiny 100/4 portait lens - Tokina made in M42 - Hanimex
(That links to the link that @marcusBMG added.)
02-02-2016, 08:41 AM   #11
Theov39's Avatar
By the looks of it, as a door stop I'd say or maybe an ornament in an aquarium or most likely as an anchor for deep sea fishing
02-02-2016, 09:12 AM   #12
QuoteOriginally posted by marcusBMG Quote
The Flashlight Test
Update
Palinar (Tokina?) 100/4 M42 preset - the smallest Tokina ?
Looks like an interesting lens. Possibly very sharp, I shall have to get it out in the sun and try it out. Thanks for the information.
02-02-2016, 09:01 PM   #13
osv
there is a lot of grit on top of the focusing ring? i would run a vacuum cleaner with brush over the outside, and make sure that there is nothing inside that'll fall out into your camera.
i've had that happen with the a7r, junk fell and stuck onto the sensor, despite first cleaning the rear glass, and blowing the back out with a rocket blower.
100mm, adapter, bit, camera, f4, hanimex, k-mount, lens, m42, pentax lens, slr lens
What are your most used lens and what do you use them for? What lens do you have that pearsaab Pentax K-5 & K-5 II 55 01-26-2021 03:13 PM
What lens was used for this ? bobpur Pentax SLR Lens Discussion 20 07-30-2015 09:12 AM
what was the cause for pentax lens price hike? clockwork247 Pentax SLR Lens Discussion 20 07-30-2013 06:29 PM
What do I look for in a used lens DeliaRana Troubleshooting and Beginner Help 5 01-29-2010 04:00 PM
What's the loudest lens you've used for a wedding? LeDave Pentax SLR Lens Discussion 14 12-11-2009 12:33 PM
All times are GMT -7. The time now is 02:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
