Originally posted by starbase218 I think this is one of those times when not being a gearhead has advantages. You only let the plastic bother you because you know of it.
Probably more applicable to gear snobs, I'm as gear heady as any gear head, but, I've known about optical plastics for 50 years and am more excited that they've made their way into high end lenses. And especially since lens rentals pointed out that plastic lens barrels are more practical than metal, and much cheaper to repair if dropped based on the damage incurred to the various components.
A true gear head, looks at the numbers, probably much like a high end designer does and makes a choice, what's the best material for this application. Gear snobs are caught up in having reasons for putting down other people's gear. It's too funny on the various sites, many people have put down plastic in lenses and gone with the "I'm a purist" tack, only to find out their favourite lens has plastic components in it. Anyone planning to go down that path, might want to thoroughly research the topic first.
---------- Post added 02-11-16 at 01:45 PM ----------
Originally posted by boriscleto I started canoe tripping with Coleman poly-ethylene canoes. The thing is, if you're new to tripping and need to work on your skills, a Coleman boat is a fantastic thing. If you start your trip with a Coleman boat, you'll finish the trip with the same boat. Short of throwing it on your campfire, there's nothing you can do that is going to destroy it or make it less seaworthy.
