02-18-2016, 10:59 AM - 1 Like   #16
Oldbayrunner's Avatar
You know, I'd have thought a plastic bag would be a bad idea... You'd potentially get condensation inside that too, wouldn't you?
If I'm going from one temperature extreme to another, I leave my gear in a padded camera bag and let the temperature slowly equalise. I do the same with international parcels now, too, as any that have come by air freight are often freezing cold. Now I open the main cardboard box and leave the parcel to stand in a warm room of the house for a couple of hours, by which time the temperature difference isn't so extreme.
No, The outside of the bag will condensate instead of the lens, the other part that is better is to place a pack of silica gel in the baggie to absorb any possible moisture inside. Usually like you I just keep my equipment inside my padded bag but If I am going from one extreme change to another I place my equipment in a baggie with silica and place them in my padded bag to sit for a bit. I keep loose baggies in my pack just in case.
02-18-2016, 11:01 AM   #17
Wow. That's some detailed and impressive explanations. Thanks
02-18-2016, 11:18 AM   #18
BigMackCam's Avatar
QuoteOriginally posted by Oldbayrunner Quote
Very handy to know - thanks for that!
Silica gel bags are always a good idea. I have them in each section of my hard camera cases, and each pocket of my camera bag...
02-18-2016, 01:14 PM   #19
jatrax's Avatar
Just remember shelf life of those is very short. Hours sometimes if exposed to a lot of humidity. They are designed to work in a sealed container and remove any moisture inside it. But once exposed to outside air they get 'filled up' very quickly. They can be renewed by heating at very low temp to drive off the moisture, but different brands have different reactions so check the specs before tossing them in the oven
02-18-2016, 01:50 PM   #20
BigMackCam's Avatar
Good point. I habitually replace mine every few months (I keep a stock of them in a zip-lock bag with most of the air sucked out). I didn't know you could evaporate the moisture from them, though... that's interesting. Makes sense, of course, but I'd never considered it. Thanks for the tip!
EDIT: Question - is there any way to tell if a silica gel bag has absorbed all it will absorb?
02-18-2016, 02:16 PM   #21
pete-tarmigan's Avatar
Buy the Pelican 1500D Peli 40 Gram. It has an aluminum case with a window showing the silica gel beads. When dry, the beads are orange. When full of moisture they are colourless.
02-18-2016, 02:25 PM   #22
jatrax's Avatar
Some brands will change color. I think the ones that just come in packets with stuff do not.
Here is some info I found:
Jake's - Silica Gel - Instructions for Use and Reactivation
My wife has a very nice food dehydrator that works a treat.
02-18-2016, 02:51 PM   #23
BigMackCam's Avatar
Cool. I'll take a look at that - much appreciated.
Food dehydrator? Forgive my ignorance - is that for making your (her) own dried foods?? I find that almost as interesting as keeping my kit dry (seriously)
---------- Post added 02-18-2016 at 09:54 PM ----------
QuoteOriginally posted by pete-tarmigan Quote
Wow, that's excellent! Will research it some more, but this could be the start of my SBA (Silica Buying Addiction)
Thanks for the info, Pete
02-19-2016, 03:37 AM   #24
kh1234567890's Avatar
A few minutes in the microwave does the trick. Don't overdo it.
http://qqjky.qjhbf.servertrust.com/v/vspfiles/info/Silica%20Gel.pdf
02-19-2016, 12:20 PM   #25
Mothballs's Avatar
Mine fogged really badly after taking a knock. I'm still getting it warrantied by my Third Party folks because the hood mount is coming off now.
TBH, I don't think the kit zoom is the best weather dealing out there.
02-19-2016, 03:52 PM   #26
It's not up to par with the and e DA* but it they still do one heck of a job. The main thing is not to stand in a torrential rain zooming away.
beads, condensation, condensation inside lens, food, gel, info, k-mount, lens, pentax lens, rain, silica, slr lens, wr
For Sale - Sold: Selling K50 + 18-55 WR kit lens + 18-135 WR lens Moropo Sold Items 7 02-10-2016 03:23 PM
18-50mm WR vs 18-55mm WR vinni Pentax SLR Lens Discussion 22 07-27-2015 02:28 PM
For Sale - Sold: Pentax DA L 18-50mm WR Retractable lens MINT bdery Sold Items 3 06-25-2015 05:35 AM
K-30 WR body + spare battery + 18-135mm WR lens + 18-55mm WR lens = 738 jido Pentax Price Watch 4 01-16-2013 04:36 AM
Pentax K-7 & 18-55 WR - Condensation Ps3737 Pentax DSLR Discussion 7 04-08-2010 09:04 AM
All times are GMT -7. The time now is 10:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
