07-04-2008, 10:04 AM   #1
Fl_Gulfer's Avatar
Fireworks Lens Choice
Of my lenses below, which would be the best to use tonight.
Thanks
Jack
07-04-2008, 11:47 AM   #2
Jack,
I just read someone on the other forum suggested to use a wide angle lens since we can always crop. So I guess your best bet with your lens will be Sigma 28-70 or Vivitar 28-90.
But again, it depends on how far you are from the site, though.
If you're inside the park maybe that will be enough.
Or you can bring them all, just in case
07-04-2008, 12:26 PM   #3
Fl_Gulfer's Avatar
Ok. I will be farely close since I live in a secluded area of beach, and there isn't alot of people here this year because of gas prices. I was wondering if my new DA-40 would work, but I hear what you are saying too about wide.
07-05-2008, 02:38 PM   #4
Miserere's Avatar
It's a bit late now for me to give any recommendations
I started off with the FA 50mm on the camera, but at 2 miles, I was too far away. Ended up using the Sigma 70-300mm APO at around 200-300mm.
I hope it went well for you!
07-05-2008, 03:23 PM   #5
vievetrick's Avatar
I would have said depending on how far away you are. But typically the wide angle would be best.
07-05-2008, 03:25 PM   #6
so which did you end up using?
07-05-2008, 07:11 PM   #7
alohadave's Avatar
I used a 16-45 and 50-200 on two different fireworks shots.
07-05-2008, 07:16 PM   #8
This is one situation where the 18-55 kit would have been a good choice. The slow aperture would not be an issue since exposures for fireworks are long and the zoom range would allow quite a bit of latitude for framing.
07-05-2008, 08:39 PM   #9
joele's Avatar
Depends entirely on how close to the fireworks you are...
I try to get fairly close normally and use the FA 35
k-mount, pentax lens, slr lens
lens choice bluekorn Troubleshooting and Beginner Help 12 06-17-2009 01:51 PM
Lens Choice SA Photo Pentax SLR Lens Discussion 3 05-14-2009 08:51 AM
lens choice dafiryde Pentax SLR Lens Discussion 12 09-26-2008 04:55 PM
lens choice dafiryde Pentax SLR Lens Discussion 13 09-07-2008 08:08 AM
Next lens choice Eigengrau Pentax SLR Lens Discussion 10 08-16-2008 06:34 PM
All times are GMT -7. The time now is 07:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
