Originally posted by BARCUD
SO, my current compact lens is 24-72 that much I know
What would be the equevalent numbers I need to look for if I want a similar lens for the K10D ?
Could an adapter be bought for the kit lens to get a similar view ?
BARCUD
24 / 1.5 = 16mm
72 / 1.5 = 48mm
Do you mean your compact camera lens is 24mm equivalent at wide angle? Are you sure? That's very wide for a compact camera. Most WA compacts are 28mm equivalent.
The Pentax 18-55mm kit lens is a bit longer at both ends, but you might find that 18mm is wide enough. IMO it would not make much sense to add an adapter, even if you could find one.
The Pentax 16-45mm lens is affordable and quite close to your specified range plus, it has better image quality than the 18-55mm. The Pentax 16-50mm is faster and sturdier than the 16-45mm and it's weathersealed, but pricey.
