Originally posted by Rai93 Ok see I appreciate the advice on how to PREVENT it, but I was hoping for advice on CLEANING it. Even if the fungus is dead and can't grow anymore I'm not leaving it on my lenses where I'll have to look at it every time I attach it to my camera lol
Well, it depends on how bad it is. You may or may not even be able to notice it. If you can, and it is in the lens area that impacts the image then it can, possibly, be cleaned.
Exact instructions are awkward since you do not say exactly what lens this is? I assume the DA 50mm f/1.8? I have cleaned fungus very successfully just using alcohol and cotton swabs. However, if it has etched the coating or glass then that damage will remain.
The difficulty is not in the cleaning, but in dissembling the lens, and getting it back together again. I have taken apart any number of Takumars and a few Pentax-A primes. Each is a bit different though in many cases you can find disassembly walk throughs on the internet. What I do not do is take apart auto focus lenses. There are folks who do, it is just more than I want to attempt without specialized knowledge. If I had bought the lens and needed it cleaned I would send it to Eric or dcshooter and pay them to do it. But paying them to clean a $100 lens is not likely cost effective. That's assuming this is indeed the DA 50mm and not something else.
My suggestion would be to wait and see what it looks like when you get it. It might be nothing you will notice. If it is serious then you have the choice of trying to open it yourself or paying to have it cleaned.
---------- Post added 02-15-16 at 08:51 PM ----------
Originally posted by stillshot2 so it gets UV light through it to irradiate the fungus
I hesitate to even type this because I know you are trying to help. But UV radiation is not going to do anything. The dose required to actually kill spores is high, and even if you do manage to apply it, the lens will be re-infected as soon as it is exposed to the air. I have seen several 'tests' that purported to 'prove' UV light killed lens fungus. What all of those testers missed was that the heat generated by the UV lamp was all it took to do whatever it was they said the UV had done. And the fungal threads they 'killed' were already dead. Remove moisture = dead fungus. But the spores remain or will re-infect almost immediately.
Originally posted by stillshot2 store it in a dry place so it can't grow or spread is what I would suggest.
Best solution. If you live in a moist humid environment consider building or buying a dry box. This can be as simple as a closed cabinet with light bulb in it to generate some heat.
