Originally posted by pres589 I've got time to assemble this kit and would be curious what gets recommended.
I travel a lot (by aircraft, around NZ and the rest of the world) and brought into Pentax for small, light and WR a few years ago. The crucial determinant is do you need WR lenses - because if you do that limits/alters the selection. For me, because I am often only in a place for one or two days - I can't wait for weather to clear, so WR is important to me and has guided my lens selection for travel.
I used to take a DA*16-50 and DA 55-300 as 2 zooms to cover a very wide range of focal lengths. I have a Crumpler 5 bag that I use as a day bag for walking about, and I can fit the K-3, 2 zooms and one small prime in the bag. Not too heavy with that combo, and I can walk around comfortably all day with that.
I have since sold the DA*16-50 and now take a HD DA 20-40 Limited (which is still WR) and the HD DA 55-300 (also WR). The 20-40 is f2.8 at the wide end, same as the 16-50, and I have found with the K-3 that I have enough ISO headroom to be comfortable with f4 even at dusk if I want 40mm FL. The big advantage of the 20-40 is it is a lot smaller and lighter than the 16-50.
If I think I want wider than 20mm, then I put the DA 15mm Limited in the bag for the day. If I think I am going to be making images of people then the DA 70mm Limited. Both small and light as the prime to add to the 2 zooms.
That is of course a 3 lens kit, where you were talking about one or two lenses, but that is where i have got to and it works well for me.
All the best with your decisions, and have a great trip
Ross
