Originally posted by Conqueror what will the 31/55/77 be like on FF?
trying to understand how these might work on FF - what they will be similar to... (the resultant FOV mainly)
imagine border sharpness might be down a bit on the 55 and 77.. may not be a big deal though
I started this Club/Thread exactly because I got very sick of all the nay saying and armchair theories that Pentax "cannot make it".
https://www.pentaxforums.com/forums/122-lens-clubs/247282-pentax-lenses-ff-club.html
The FA limiteds are fantastic lenses even on FF digital.
I use a A7 modified with no AA filter and thin filter mod, so its resolution is pretty good already.
Do note that since the FOV+working distance changes, it CAN change the dynamics of how you use the lens.
I've ended up really liking the 77ltd even more, having the 31ltd become a super versatile one lens (rather than just a niffy 50mm FOV on apsc), and the 43ltd fall out of grace somewhat because what was a 'shyish'/fast 60mm has become a more aggressive 43mm for street photography
So whether it will work better/worse/no-change will certainly depend on the individual.
As to the "accusation" that 36mp will be harsher.
It all depends on how the user uses it.
In fact the context is often wrt either off center wide open or stopped down performance.
Some guys are just not that realistic imo when it comes to the former (how sharp do they want, when a lens is wide open?? )
If its stopped down, most lenses 28mm and up will be no issues.
Old UWA may not be as good off center or on the edges/corners (and filter stack + sensor type plays a role here too).
But then, to be fair, Canon has never had a great UWA for edge performance in its 17-40L; 16-35/2.8L and L vII either. (neither cheap, small nor old lenses)
So in summary, from me, if its 28mm and above and the lens was good on apsc up to the edges (for stopped down work), use with confidence.
Most good lenses when used on FF wide open, center will still be sharp and the off center (rules of thirds area) where most subjects will be placed are still sharp enough.
Only when the lens has a known design characteristic that is mainly central sharpness until stopped down a bit (eg. Sonnar; Biotar, etc designs) will the off center (rule of thirds area be less sharp) wide open.
