Originally posted by JensE One more opinion on the somewhat tangent discussion on 18-135mm vs. 16-85mm: As somebody having used the 18-135mm a lot, I would still recommend the 16-85mm over it for somebody who is OK with its size.
Why? I do love the size, weight, very quite and relatively fast focus as well as the excellent WR of my lens and have likely taken my best pictures with it. But, most of it somewhat of a rehash of the above, there are some points which I learned from experience:
1. The wide end of the 16-85mm is really useful e.g. for 'cityscapes'. While I own the 8-16mm Sigma, I now typically leave it at home and only use the more recently aquired 15mm LTD and suspect that most of my travel needs would even be served without it using the 16-85mm. I often found the 18-135mm just a tad too narrow.
2. On the long end, zooming out beyond ~100mm does not actually give considerably more detail than cropping the 100mm on my 18-135mm, at least with less than ideal light. Over most of it's range, not only corners but also the short edges never fully sharpen up on mine when stopping down the aperture. Not a problem for the vast majority of compositions, but it gets much more pronounced at the long end.
3. Contrast wide open at the long end is notably lower than in the middle range.
4. The image circle covered by the 18-135mm seems to be a little small. I sometimes end up with heavily darkened corners. I suspect it is due to sensor shift being involved, that those steep fall-offs are uneven and not correctable by lens profiles, sometimes very hard to fix. I need to spend a lot of extra work in post-processing when this happens. It's hard to predict or control at time of exposure.
Altogether, it's often advisable to frame picures more generously with the 18-135mm and leave room for some cropping, effectively reducing the level of details captured.
So, with limited usefulness of the long range, if I it wasn't for the the very compact size of the 18-135mm, I'd avoid the compromises made for it and take the 16-85mm for a single zoom.
Well isn't that always the compromise, more zoom range especially in cheaper lenses often means less quality over the whole range. The wider aperture the more weight.
Here are some examples from the 18-135...
AT 31 mm...
Sharp everywhere
Right to the edge.
At 135mm, sharp enough for 1280 pixel wide images
Soft on the edge...
A great deal of the time with telephotos soft on the edge doesn't matter, and isn't even noticeable even in large size printed. This image by the way is good enough print large, taken at 135mm. And no, a 16-85 wouldn't come close to this in IQ. This is what you give up if you select 16-85 over the 18-135.
The 18-135 and 16-85 are both walk around lenses. I don't consider either to be good enough to use for images i want to try and sell, but for 4x6s and web sized images, they both do just fine. Compared to my 60-250, the16-85 at 85 mm is coming off the camera as soon as I can use the 60-250, it's only average at 85mm.
So from my perspective neither is good enough to stay on the camera all the time and neither is good enough to stop me from putting on a better lens if it matters. To me this is just hair splitting. A tempest in a tea kettle. Making distinctions by limiting your choices to "the best of average." If you want quality, get the Tamron 17-50. It's much better than either of them, and it's quite possible you can blow the Tamron up to the equivalent of 85mm and have just as sharp edges as the 16-85 will give you at 85mm.
If I want to print large, neither of them is going to be on the camera, so from my perspective nit picking about which is better, is kind silly. Go for the focal length you want, the weight you want and the aperture you want. They are both walk around lenses. Arguing ultimate IQ on a walk around lens is kind of like admitting that you have to settle for less than the best and wondering how much less you can get away with.
That's a reasonable thing to do, but neither of these lenses is going win any awards for their IQ. But, that doesn't mean you can't take award winning images with either of them.
