I use SMCP DA35 Macro Limited f2.8, on K-3.
I don't do insect shots, and 35mm is a good macro focal length for me.
This lens is excellent for product shots, where you get close up to small objects. Anything from a button to a brick, say.
It renders images with the typical "DA Limited look", deep contrasts, superb micro contrast, and just gorgeous colours.
The level of fine detail is jaw-dropping. It just has a way of extracting fine detail I don't see elsewhere. Macro range bokeh is superb.
I also use it as a general walkabout lens; it's very versatile indeed, and fairly fast @f2.8 (and sharp wide open). Stopped down, the sharpness is, again, just stunning. Bokeh ranges from acceptable to very good. And all this with the "DA Limited look" mentioned above.
Mechanically speaking, it's compact, robust, has Quick Shift focusing, no WR.
