07-07-2008, 10:32 AM   #16
Big Dave's Avatar
Hi,
Are you sure about your FOV numbers? The seem a little wide to me. Are you giving full frame FOV or APS-c sensor FOV? I get 90 degrees from my 14mm on a DSLR.
Dave
QuoteOriginally posted by vanchaz2002 Quote
You are looking for rectilinear lens shorter than 16mm, which leads to FOV of around 110 degree. There are a few options available including the already mention DA lenses.
Tamron has 14mm one covers 115 degree. Pentax has K18 covers 100 degree. Tamron one is fairly expensive and K18 is MF, hard to find, and relative expensive.
Zeiss has its new distagon in 18mm fits Pentax. It covers FOV of 99 degree. Sigma also has a relative cheaper 14mm but not sure it come with Pentax mount.
Basically, rectilinear lens are hard to build, especially over FOV of 100 degree. Said such, ultra-wide rectilinear is most likely an exotic and luxurious option.
So what left for budget hunter is using a fisheye lens and covert the image in computer. I believe Photoshop has plug-in that can do the job. Internet has enough information of fish-eye to rectilinear conversion.
Hope that helps, good luck on lens hunting.
CY
07-07-2008, 10:55 AM   #17
You could be right on your numbers. My calculation is on full frame.
For digital camera with 1.5 crop factor:
14mm is around 90 degree
15mm --> 87'
16mm --> 84'
17mm --> 81'
18mm --> 77'
Thanks for bring that out.
07-07-2008, 01:48 PM   #18
QuoteOriginally posted by Light_Horseman Quote
I'm hoping the greater forum knowledge can help me find a good ultra-wide prime lens. I'm looking for something 16mm or less focal length and not a fish-eye.
I would love a Pentax 15mm rectilinear but they are hard to find and very expensive, so I'm looking for an alternative. I'm not particular about brand or speed, just as long as it is decent quality.
So what are my options and what should I look for.
Cheers
LH
I have a Sigma 14mm 2.8 that I would consider selling as I don't use it enough to warrant keeping....I tend to shoot more towards the long end. If you think that that would suit your needs PM me .
Tony
k-mount, pentax lens, slr lens, ultra-wide
Ultra Wide Angle Zooms buster110 Pentax SLR Lens Discussion 33 06-22-2012 07:42 PM
Ultra-wide angle - are there little known gems? Flickeroo Pentax SLR Lens Discussion 40 02-04-2011 01:11 PM
Ultra-Wide Choices? potatolicious Pentax SLR Lens Discussion 16 10-29-2009 05:36 PM
Best Ultra Wide Lens ? monkeybear Pentax SLR Lens Discussion 18 03-20-2009 07:28 PM
Ultra-Wide Angle Recommendations tux08902 Pentax SLR Lens Discussion 17 01-14-2008 10:33 PM
All times are GMT -7. The time now is 06:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
