Originally posted by ThorSanchez I'd considered the 10-17 when I got the 8mm Rokinon,
I have rented the 10-17mm several times, and really like it alot,it is an amazingly sharp lens, at US $305, you really can't go wrong.
I ended up buying the Rokinon 8mm instead for three reasons:
1. Have a Takumar 17mm, so I was covered for an almost rectilinear UWA (it aonly gets fishy when objects are close, but not much for landscapes on the K-5)
2. After renting the 10-17mm for different occasions, I found that I was really using the 10mm end more often, I like fishy shots in a variety of interior and exterior settings (If you crop, a lot of time you get a fairly undistorted UWA panorama, even at the 10mm end.
3. A Pentaxian put a Rokinon 8mm up for a fair price, and when taken into consideration with the other two reasons above, this was the deciding factor.
Obviously you have a few months to decide, I
still suggest renting both lenses rather than guessing or buying both. If your schedule is like mine, you probably do more shooting over the weekend. You can rent for as little as three days, and if you do it right, you get Sunday for free and mail it back on Monday. I don't know where you live, but even on the East Coast you can find plenty of wilderness under an hours drive, even from NYC.
Also, consider joining one of the groups in my signature below, I look forward to seeing your pictures.
