I don't use my 40mm xs very often. I carry it around with me a lot, but it rarely gets fitted to the camera. Most of the time I'm using it, it's to show off how tiny it is.
It was a beautiful day in Baltimore, and I parked (illegally as it turns out... $80 in tickets later) near Federal Hill to take some photos of the city.
I had my 50-135 on the camera, and the 15mm with the 40mm attached using a double lens cap.
After getting shots with the zoom and finding a park bench to plop down on (I didn't bring anything to put the 50-135 IN if I dismounted it, so the park bench served that purpose), I played with the 15mm for a bit, then decided that I hadn't used the 40 in a while and it deserved some use, too.
And nothing seemed to be in focus, at first.
Then I realized the center was in focus, but nothing else seemed to be.
At first I assumed something had gotten smeared on the lens - it reminded me of that effect. But I took it out, took the tiny BW filter off the front, everything was clean.
I panicked and put the 15 back on, and it was fine.
Put the 40 back on and switched to live view and tried manual focus... no luck.
It looks like I'm using a lensbaby. - See attached, full image, detail from center and near edge
It wasn't like this the last time I used it, in, ... uh... April 2015. (attached - last photo I'd taken with it on that outing)
What do you guys think happened? I'm assuming I banged it on something and messed it up, but I'd have expected it to be messed up across the board or unevenly, and this looks at least at first glance to be pretty even (center in reasonable focus, rest smearing off)
