Originally posted by clackers That looks pretty bad, John.
I agree. The plane of focus appears to be somewhere around the large tree at right center. I would expect the concrete pillars at the same distance right to be reasonably sharp and they are not. At f/8 with the plane of focus at 150' there should have been reasonable DOF from 4.5' to infinity. I would expect the foreground grass to be reasonably sharp and it is not. In addition, the foreground and corners appear smeared.
I have to ask...was there a filter mounted, by any chance?
Assuming there was not something else in the optical path (filter, grease, salt), I suspect this lens has bad problems.
(...did a short demo with the DA 15 when it first came out and it was quite adequately sharp across the field...)
